Switching 220v with K8090
Hi There,
As seen on the site Velleman.eu, it says that the K8090 is capable of switching high power 16a. Is it also capable of switching 220v? How should it be attached, just in a serial way? or does the K8090 contain a power input for switching all relays?
Love hearing from you guys
Enlarge the pictures on the site of Velleman of this kit and you will see that only the relay contacts are connected to the outside world by means of connector blocks. So there is no general input, you only have 8 “switches”.
Normally the relays used are suited for 230 V AC. But with inductive loads Velleman recommends using VDR’s (space available on the PCB).
