support in pla is harder to remove then abs, but if you use a slicer where you can edit your support like in Simplify3D you can make it easyer to remove or even delete support on parts where you won’t really need it.
But say in Cura, what is the lightest type of support, any settings to play with?[/quote]
IMO, Simplify3D does not justify 149USD!!! Yes it solve some problems with supports and filament waste but it does not justify 149USD!
My advice to you: before wasting 149USD try Autodesk Mesmixer. It has a somewhat learning curve but it’s easy to use for creating supports. Also you can find alot of tutorials in youtube. Oh and did i mentioned IT’S FREE!! ??
Alot of companies use it for their works.
Cura isnt the best when it comes to support, but I find it usually fairly easy to remove. I like slic3r better, but it has its own problems. But you may be overextruding, which might also explain why your print are glued forever to the blue tape.
