I was printing an object with an ooze shield today, but after a few layers this shield stopped working. I was using a shield in favour of a wipe and prime tower because they always seem to fall over and leave a stringy mess on the object.
I am using a modified ABS profile with a lower temperature because the HIP keeps oxidising - causing black marks on my models - and because the heater struggles to get to that temperature. It shouldn’t matter because the [color=#0000FF]glass transition point of poly(styrene) is around 107°C.[/color] Nevertheless the same issue occurs when using the default temperature.
[quote=“VEL327”]Did you check the length of the PTFE tube inside?
Does the same thing happen when you switch the materials around (PLA in HIPS extruder and other way around.)[/quote]
Thank you for the response.
I was very careful to make sure the PTFE tube inside the hot end was the right length, but out of interest how might that cause the issue?
I do not currently have access to my printer but when I do I will update this post with the result of swapping the materials over.
