I just un-earthed my 2 channel Velleman pc storage oscilloscope 32ms/s. The old one with a parallel port.
I can’t find the manual or the software for it and it doesn’t appear on the support pages here. Does anyone know where I could download them?
Unfortunately it doesn’t have a part number on it. That’s part of the problem.
But here is a photo of it; hoping someone can identify it. https://goo.gl/photos/3Wi6qDbeNob2T6o18
Does this look like either of the part numbers suggested above?
It seems to be K7103.
The software for the PCS32 works for it too.
Select: Options->Hardware Setup
There select K7103 and select also the LPT port number where the oscilloscope is connected.
You’ll find the port number in the Device Manager.
For more info see: viewtopic.php?f=10&t=936 viewtopic.php?f=10&t=2154
If the installation program is not compatible with your Windows version, you can try following solution:
Download this ZIP package: box.net/shared/ny0kk9bpkq
Extract it to a folder and run there WinDSO_FG32.exe.
The oscilloscope K7103 can’t be used with 64 bit Windows versions.
Thanks for your reply. It does seem to be the K7103, unfortunately it seems from this forum that i stand little chance of getting it working on my PC with no parallel port, running windows 10. Looks like I’ll have to replace it,
