for a project I use several of your Velleman Relaiscard K8090 which will be controlled via USB. Now I have Relaisboards with a defective Relais. I wachted out for a replacement Relais, but I couldn’t find one that works in the circuit. It seems very tricky if the coil not have the exact resistance it leads to a unfunctinally Relais channel.
Can someone tell me where I can buy the originally used Relais in this kit?
Very useful if I can get a link to a shop or a distributor who sells this originally used Relais.
Best regards
André Brändli
