STL > Solidworks > STL
Hi
i just adjusted a STL file in solidworks and saved it back to an STL file. Now my slicer reeds the new part but it is hugh… Does anyone know how to save an edited STL file to its normal size instead of making it like 100 times bigger? thnx
When you open a STL you must click on Option before importing it and select the units (default = meters so your object is 1000 times bigger if you don’t select millimeters).
