Stepper motor wiring on Ramps 1.4 vs Velleman controller
Can anyone help me with the following:
If I follow the original assembly guide for the K8200, the steppermotor wires are attached as follows on the original K8200-Controllor:
Blue (stepper) -> Blue (band) -> Yellow (connector ) = 1B on PCB
Red (stepper) -> Green (band) -> Orange (connector ) = 1A on PCB
Green (stepper) -> Yellow (band) -> Red (connector) = 2A on PCB
Black (stepper) -> Orange (band) -> Brown (connector) = 2B on PCB
If I now look at the pin sequence of a Ramps 1.4, the sequence is the same (1B-1A-2A-2B), however, all the color pictures I see on the internet (and in @Dr_Vegetable 's description of the Dual extruders on a Ramps), I see a color sequence for the steppers of Red(1B)-Blue(1A)-Green(2A)-Black(2B), so the Red and the Blue wire have changed sequence.
So is it needed to rebuild the connector plug, or can I still use the original sequence?
Thanks in advance for a reply
