Hi I have just completed the electrical part of a K8200 build. Having checked all the wiring prior to connecting to the controller and installing all the software. When I use repetier to drive the stepper motors in manual mode. I find that only the X-axis motor will do anything.
Before I started to manually control the motor’s I adjusted the reference voltage as described in the instructions all to 0.425V +/-5mV using a plastic tipper trim tool.
I have read / assume that there may be a temperature related lockout on the extruder drive?
Having found that the x-axis motor & wiring seems to work. I removed the other motor connections from the controller and I tested each axis by connecting the x-axis motor to each motor port in turn. I still find that Y, Z & Extruder outputs don’t do much. The ‘step LEDs’ on the controller flash with manipulation of each axis but no motor drive.
My final test was to revert to connecting the x-axis motor to the x-axis motor output of the controller and test each of the motor drive modules in turn into the x-axis stepper module position on the control board (obviously being very careful to ensure that they are fitted in the correct orientation) I find that only two out the the four modules work??? These are supposed to be new modules and have been treated as such in accordance with usual anti-static handling procedures. Each module has probably been connected to a power supply for around 3-5 minutes.
I read that there seem to be many other users with duff stepper motor modules from the start? Is there no quality control?
Following an evening of annoyance:
1/ how do I go about getting these modules replaced?
2/ what are the typical failure modes of these modules. Is it the stepper motor driver chip itself / solder joints / components?
kind regards
Geoff
(Electronics engineer)
