I finished assembling of my vertex k8400 with only one print head few day ago and i was unable to make it print. For the first test, everything has worked well but the fillament wont extrude ( even if nozzle is > 200 C ) and the printer was moving in X/Y/ Z fine. i tried older firmware, change the voltage of the stepper driver. But since i changed the voltage of the extruder driver. X/Y stepper wont work anymore when i try to print or make go home the head. then i try to change the voltage of X/Y/Z driver too but nothing has changed)
what are the good voltage ? ( not 0.9V its the minimum voltage that i can set with the trimmer and nothing move)
(and the extruder probleme is still unresolved)
any clue ? any help would be apreciated.
