Step 008, motor bracket problem
Dear Service,
I have a probleme with the step 008 (X Drivetrain).
The motor bracket holes are not in the same place that shows your picture?! (they are centred) due to this the belt touch the upward part!
Please let me know how to proceed to obtain the right part??
Thanks in advance for your support.
Best regards,
You need to fill in the form and to specify which piece do you need at this address :
k8200.eu/support/missing/
It looks like the part you have is for the Z motor mount.
The extra hole is for the end stop switch.
You should look at the Z motor mount maybe they got mixed up.
If the did you will need to switch them because in chapter 12 you need to mount the end stop switch.
[quote=“Wrong Way”]It looks like the part you have is for the Z motor mount.
If the did you will need to switch them because in chapter 12 you need to mount the end stop switch.[/quote]
Already checked unfortunately this is not the case!
I will try to obtain the right part asap…
You are correct, this is an error, please fill out the form to get the correct part:
i have the same problem but I think I can drill 2 new holes of my own:
How many mm do I have to move the holes, I think its about 9mm. Can you check please?
Greetings, Marco
i drilled 2 holes about 9mm away from the wrong holes like shown above. Worked for me perfectly.
Greetings, Marco
