Our grandson has soldered very careful the packet with Rudolph.
This is now ready and we will try it with the example software but it does nothing.
Can you help us with the startup from Rudolph please?
Greetings,
Luc (grandfather) and Kobe (grandson)
Van: system via Whadda forum - Community Help and Support noreply@forum.whadda.eu Verzonden: vrijdag 7 januari 2022 16:03 Aan: luc.coppens@telenet.be Onderwerp: [Whadda forum - Community Help and Support] [PM] Thanks for spending time with us
Hey there. We see you’ve been busy reading, which is fantastic, so we’ve promoted you up a trust level!
We’re really glad you’re spending time with us and we’d love to know more about you. Take a moment to fill out your profile, or feel free to start a new topic.
it’s not clear from your description, whether the kit worked on first boot (with the pre-programmed factory code), or it doesn’t work anymore after programming the example code.
For Powering the “Rudolf” - WSPXL101(2), you’ll need to connect the supplied USB Cable (A male to B male) to “POWER ON” Connector, Labeled “SK1” and to a USB compact charger (5V / 2,1A).
No need to connect the Nano Every via micro USB cable to PC, to power up the kit and programming (this is only needed for programming the nano every).
power supply: 5 V – 2.1 A max. (cable incl.).
The programming manual for the example codes of Whadda XL, you can find it here:
The Original pre-programmed factory code => you can download it from here If you want go back to original, you can upload the factory code, because after upload an example code, the original code will be overwritten.
To cycle through the different modes, press the mode button.
