No matter what I do, I can’t get to accept SD.
Funny thing is, if I insert SD and start Repetier and select SD at manual window. I get an overview off files on SD and can start print.
No matter 32Gb, 16Gb, 8Gb or 4Gb same problem, at stand alone no files on SD.
I insert SD and pres reset, then use thumb wheel and get NO SD present.
Please HELP I want too set it up in STORE display tomorrow!
[quote=“hudibras”]No matter what I do, I can’t get to accept SD.
Please HELP I want too set it up in STORE display tomorrow![/quote]
Hello Hudibras,
I’m using Vertex3D printer stand alone. I try to explain:
1- My Vertex3d printed “not connected” to the computer.
2- I put sd card to built in card reader in my computer.
3- I open Repetier-Host.
4- Load a *.stl file.
5- I slice it with in Repetier-Host built in Cura slicer.
6- I choose G-Code tab.
7- There I choose save G-Code symbol.
8- I save G-Code to the Sd card ( in my case E: drive)
9- Then I remove Sd card.
10- Plug sd card to the Vertex3D printer.
11- Plug printer cable to the wall outlet (230 volt)
12- Then choose on the printer “init sd card”
13- Then choose “Change sd card”
14- Then choose “print from sd”
15- Then you will see G-code file what you saved before in your computer.
16- Choose this file then it will start to print stand alone.
All this steps takes 5 minutes + printing time.
Regards
Niyazi
[quote=“niyoki”]
Regards
Niyazi[/quote]
Tried again, but jumped in at point 12 I thought it ment format.
Does autoprint work?
[quote=“hudibras”][quote=“niyoki”]
Regards
Niyazi[/quote]
Max Nielsen[/quote]
Hello Max,
I had some times difficulty to get sd card working. Then I found the case opening for sd Card Input from the Vertex3D and sd card Reader module was not overlapping right, I grinded the Plexiglas case opening a Little and loosened screws that holding sd card reader and lcd module for overlapping better than before. After this alignment it works real good. But sometimes when I touch sd card then it looses contact, after I restart Printer it is again working nice. Because of this please don’t touch sd Card while printing…
it only requires a raspberry pi and, if needed, a usb wifi adapter, and for the timelaps/monitoring you can install a camera. Installing/configuring the software is very straightforward.
There is also software for your phone so you get a notification on the status of your print.
I’m currently using Slic3r and got the vertex connected to the raspberry pi through USB; octopi uses a key (API) that enables you to hook it up to slic3r. In slic3r you can select ‘send gcode to printer’.
I know Cura is the most recommended slicer for the vertex, but I get much better prints with Slic3r. Slic3r is simple my preferred slicing tool.
