Spool Holder for 95mm spools
Hi@all,
is there a chance to get a spool holder for 95mm spools?
The diameter should be the same like the original. But my spools have bright of 95mm.
I’m using this filaments:
amazon.de/gp/product/B00HDG3 … ge_o03_s00
And I’m new by building a 3D model. So I cannot make it by my own.
Is there someone who can build one?
This would be a great support!!
Thanks a lot for help.
I’m not 100% sure but I think most spools would come as a 1kg roll.
The ID (Inside Diameter) of the spool is (from memory) around 50mm.
Most spool supports that I’ve seen are conical - this allows for variation in the ID of the spool.
Try thingiverse for some existing designs:
http://www.thingiverse.com/
For 3D modelling, I found this to be fairly user friendly for a beginner:
http://www.123dapp.com/design
Just remember to define a 2D shape first (you can only work in one plane at a time).
Hope this helps.
thingiverse is nothing to find for this spools.
And at the moment I’m not able to creat it by my own.
So I need help to get one part for spool holder with a bright of 95mm.
The diameter of the holder should be the same like the original of the vertex spool holder.
EDIT:
Found this:
thingiverse.com/thing:601994
Hope this will fix my problem :wink:
ANOTHER EDIT:
It was exactly was I needed!
The spool is perfect for my filament.
