Speed regulation K2636 - motor compatibility
I’ve a question on the K2636 motor speed regulator
I’m not sure whether it can be used with this motor:
https://drive.google.com/folderview?id=1B77b1SUPWgMj8DGyAnpHFnHvi2a6yjh7
This is a very old German-made motor coming probably from a sewing machine. (The factory had Dr. Max Levy’s name seemingly before 1929). Unfortunately, I am not an expert and cannot describe it in more detail.
My goal is to use the motor for an old watchmaker lathe. A good speed regulation is needed in order to be able to run the lathe at low speeds. I would like to avoid making a transmission but rather regulate it electronically (preserving the torque as much as possible).
I will be grateful for any advice.
Andras
Dear sir,
The K2636 can only control motors from the “Universal Motor” type only.
for more info how to recognize this type of motors:
