Hello
I just started with the Vertex K8400 and I’m having some troubles. When I print the Vertex logo with default settings, I always get spaces between seperate lines.
I tried a few things, but with no better result. What can be the problem of this?
What slicer and host program do you use
And can you show your settings of that program in here
[quote=“patter”]What slicer and host program do you use
And can you show your settings of that program in here[/quote]
I’m using Repetier-Host of the Vertex website:
Slicer: CuraEngine Print Conf: VERTEX SINGLE HEAD Adhesion: None Quality: 0.1mm Support: None Speed: Slowest Density: 20%
Extruder 1: PLA-1.75MM
https://www.dropbox.com/s/4v2o61hvtnccu9l/20150623_223707.jpg?dl=0 https://www.dropbox.com/s/fdzy3hwgnfaqocj/20150624_140133.jpg?dl=0
