The kit i am talking about is the sound to light kit MK103 which can be found here http://www.velleman.eu/distributor/products/view/?id=337995
What components do i need to change or upgrade to get a higher milli amp output. What i am looking to do is get 1 amp out of the output where the LEDs are placed and remove the LEDs so i can put output transistors so i can run another device on one kit.
If you can tell me how to do it or what i need to change in clear instructions then i will be buying up to 3 more kits and converting them, as it stands i estimate the velleman kit can only put maximum of 200 milli amp out and the component on the kit will not stand a higher output.
Please can anybody help, i understand you do not like any modification done to your kits but it is strictly for myself only and nobody else.
Thanks in advance
