Some of my 3d-prints after a week of happy printing with my new vertex! (my first 3d-printer):
fourth print and real test after the usual “vertexlogo”, “powersupplycover” and “vertexbraclet”
Test with a “big thing” (aprox. 11x11x11cm) with a lot of gapes and only thiny connections and a lot of overhangs!!!
Extruder at 210°C -> unusable, lot of lines, flying wires and dot’s … so i reduced the extruder temperatur down!
Extruder finally at 190°C (!) -> much better (top 3 cm of the print)
… then I needed a usable powerconnection with powerswitch
designed wit autodesk 123D
… Robot on candle-light-holder
Printed all full speed with extruder at 185°C (best surface and all movable parts are working very fine)
sorry for my bad english and wish a nice evening with some good prints
@nevarore: read this article as it might point you in the proper direction: viewtopic.php?f=62&t=13267
I had the same issue but now it’s printing fine!
Great prints! Could you share your powerswitch STL and components list / how-to?
I’ve no idea why there isn’t a simple power switch as part of the kit, I currently have to crawl behind my PC to unplug it. Very annoying and just silly!
@biscuitlad & h60: No, the published one in thingiverse is not mine! (Bigger switch an other power connector)
Perhaps I create a account in the next days by thingiverse, or you send me a pm, so I can e-mail you the file …
Robot with movable parts _> don’t reduce the flow … just reduce the temperatur (it’s wrong with original firmeware) or change the firmware (other Thermistor nr. 10)
[quote=“lem”]Hello, @biscuitlad & h60: No, the published one in thingiverse is not mine! (Bigger switch an other power connector)
Mike[/quote]
I think it would be best if you did it on thingiverse with some instructions, that way more people could use it (without hassling you each time!)
These are both from le FabShop on Thingiverse. They both print as single pieces, no support and yet have moving parts! Very easy way to impress people.
Like most people I reduce my temperatures to around 190, think you get a better surface finish.
