Hi
I just finished assemble the printer, but I have a few issues.
The PCB bed ins’t heating up, the bed only register 0.0c in Repetier, is it possible to messasure with a multimeter if the soldering is correct with the thermistor? If so, how?
The second problem is when i manually control the motors. After they moved and stopped, they give out a little bright “buzzing” sound, like it is still active, only when i press “Turn of motor” the sound goes away, is that normal?
