Just finished building my K8200 printer from a kit. I’m using Windows 8.1 on an Alienware laptop [ 16 Gb ram ], but having problems downloading things like the drivers and Version 0.84 of the Repetier Host [gives error fault]. Don’t have problems downloading version 0.95 from the Velleman website [slightly different in the setup procedure]
As for the voltages and adjusting the trim pots on pin 2 [ as in the pictures in the manual] [very small and narrow pins of the miniature chip. Pity there is no provision for a dedicated spot on the driver boards for this] of the driver chip to 0.425V, I don’t get any variation of voltage on all stepper motors [ all 0 Volt], but don’t think I correctly downloaded the drivers to the board, but I have tried several times with no joy.
Maybe I didn’t understand the instructions properly, but I’m looking for ZIP files to elimate faults or errors in downloading and transferring to the board. There is a voltage of 4.98 V on VDD of the circuit board below the stepper driver modules on the main K8200 board. In the building of the kit, I double checked before soldering all the connections.
On powering up the board there is a green LED that flashes twice then goes off near the Y STOP plug. A green and red LED lights up when the USB [ USB 2] cable is attached at both ends when the power is off. When power supply is connected the USB these LEDS actually go out. Not sure if the details I have given are of any help. When the drivers are downloaded will the USB LEDS flash at all?
Any help would be appreciated.
Don
