I’ve made a lot of tests to avoid these small strings on the first layer:
I suppose this is a retraction issue and tested:
Retraction speed: 90 - 150 mm/s
Retraction length 3 - 7 mm
Temp: 190° - 210 °C
None of these settings worked and I’am not even sure if there were changes at all.
What else could I test? Should there be a „visibel“ or „feelable“ retraction of the fillament with these settings? I feel small little „ticks“ but no retraction of several mm.
Temp: 190° - 210 °C
Regards
Chinch[/quote]
as far as i know you can see very cleary that the filament is retracting.
The best retraction parameters are : 3mm -150mm/s. But you can’t avoid a tiny oozing of the filament. Moreover there’s no retraction when the head travels within the print boundaries. The oozing is covered by the next layer so it matters a lot less.
[quote=“Chinch”]Do you know the reason for this behavior?[/quote]As the oozing is covered by printed layers or is in the build volume it’s supposed to be invisible.
You’d better print with low temperatures (190 for PLA and 220 for ABS). The higher the temperature, the higher the oozing.
