My printer sometimes leaves a gap between the outline and when it’s filling it up with plastic, the picture does a much better job at explaining the problem.
This usually happens with smaller prints.
Anyone know what causes this and if there’s a fix for it?
Try setting the infill overlap parameter to 10%. And check the sliced object layer by layer to see if there’s no gap between the infill and the shell. You can also modify the shell thickness to get a better result (by steps of 0.1 or 0.2 mm).
