I´d like to be able to do two things in Cura and I can’t seem to find the settings for it. Perhaps some of you guys know how to do it?
I’d like to set the last two layers to be solid infill. I think this was possible with k8200 in slicer?
I’d like to automatically change print speed to like 20-30% when it’s printing overhang section. Is it possible? For some parts I can’t use support since the geometry doesn’t allow me to properly remove the support afterwards (tight fit with a bearing in a long hole afterwards).
If anyone know how to do this I’d really appreciate!
[quote=“johanmoberg”]I’d like to set the last two layers to be solid infill.[/quote]Only way is to increase the top layer thickness but the bottom layer is also affected.[quote=“johanmoberg”]I’d like to automatically change print speed to like 20-30% when it’s printing overhang section. [/quote]That can be done with Slic3R (which is the default slicer for the k8200) but not Cura.
Ok ok thanks! Would a manual approach work? I’m thinking checking between which layers the overhang action is, adding g-code for slower speed and in the end returning to full speed?
in S3D you could generate multiple processes, which can have different speed at a certain hight of the object.
Maybe that can be done with the original software as well (?)
I have no idea about the original one, since I quit that before even starting with it.
Switched on to S3D on first print
