Dear Forum members,
I am a new user with a Vertex K8400 3D printer and I have a problem what I do not understand how this is.
I want a field of 13x9 cm and 2 mm thick printing with a profiling.
The Skirt and Brim is nicely printed, then starting the infill from a corner under 45 degrees, that’s going to far, so good. But then de infil extrusions wil be printing as wavy.
The bed is adjusted to 2 x double folded A4 80 grams. Checked again.
Why do I get the Brim and Skirt be fine then on the bed as well as turning on the interpretation, see pictures?
An earlier print: dropbox.com/s/xo9duns8o90yo … 0.JPG?dl=0
As you see are the extrusions not against each other, then it would need to be adjusted according to the manuel “extrusionwidth” (?).
This download does have the mostly correct ini files installed.
You need to make the following changes in the Cura slicer settings.
For PLA Hot end temp 190C
Change the retraction to 3mm
Retraction speed 110mm
Gentlemen,
The entire day in the sign of the K8400.
CuraEngine set to the value above. Slicing it. Print command. Printer responding. After that, nothing more. Printer gets no commands. Requested temperature stays at 0.
Printer is fixed. The printer can only completely off and reboot. Tried again but I can’t!
Tried again with Slic3r and the printer works again. Only getting the same problem. Nozzle distance at different distances put nothing helps.
It seems like the filament hits the bed not well/attaches. Too little pressure to the filament on the bed (?). Should something happen to the supply? When displacement of the filament, there is a lot of pressure on the filament, jumps the imported filament thereby becoming something back through the roller, this can then with and “P” sound.
Last stand: Nozzle height at 3 x 80 gram paper is 0,40 mm and the first printing layer is also 0,40 mm thick.
By unload and load of the filament, see what comes out. A string of 0,35 mm so that should be good.
