HI I can´t slice this probably.
What can I do ?
Tried change some settings.
It is about 10 x 9 x 8 mm in size.
thing:33480 only pea
Thanks for any help
What can I do ?
Thanks for any help
Looks like a job for meshmixer to split the objects and then print them separately.
The pea doesn’t slice right indeed. Try to repair it with nettfab basic.
The walls are to thin.
It only slices correctly ant nozzle size setting below 0.4mm.
It’s a slicer issue. With Slic3r it slices normally.
