Slicer
can someone slice this for me with support under the car itself, my computer keeps crashing and errors on this file and i need it for a project
it is this file
thingiverse.com/thing:221885
thanx in advance
Hi AÄronR,
that might be difficult, since we don’t know the settings and limits for your printer, your filament, etc.
Cheers,
kuraasu
Note that this piece will look really bad printed on an original K8200 anyway.
~ Tectu
@ kuraasu
my 3d printer is the k8200 with black pla fillament of velleman, can i send you my configuration file via email?
Hi AÄronR,
sorry, that would be of no use. I had a look at your model, and it seems to me that it’s not Slic3r’s fault to crash.
Your stl file has very bad balance between raw and fine resolution. While the shape of the car itself is made up of a seemingly moderate number of triangles, some small portions are defined by an enormous amount of facets - most prominently the outer surfaces of all four tires. Those are hardly complex surface geometries, so it’s simply a very bad case of high-definition gone wrong. It is also the most probable reason for Slic3r crashing on this object.
If you have the base data for this, or some software capable of a) operating on such large stl files and b) combining facets you could reduce the (unnecessary) resolution in order to create a usable object.
Cheers,
kuraasu
