Slic3r> unable to resolve overloaded method for Wx::ComboBox
Thank you so much for your answer. That helps me aot and it works out.
now the 3d printer is ready to print. but still, i have a problem with the slic3r. I have downloaded the K8200 PLA standard download of zipped file and I just extrat the zipped files.
  1. I clicked the slicer button and then click active, and then when i clicked the configure button. I have got this message.
    11:16:06.360 : Unknown option solid_infill_extruder
    11:16:06.360 : Unknown option infill_first
    11:16:06.360 : Unknown option solid_infill_extrusion_width
    11:16:06.360 : Unknown option infill_only_where_needed
    11:16:06.360 : Unknown option max_volumetric_speed
    11:16:06.360 : Unknown option external_perimeters_first
    11:16:06.360 : Unknown option support_material_interface_extruder
    11:16:06.360 : Unknown option support_material_interface_spacing
    11:16:06.360 : Unknown option support_material_enforce_layers
    11:16:06.360 : Unknown option top_infill_extrusion_width
    11:16:06.360 : Unknown option standby_temperature_delta
    11:16:06.360 : Unknown option bridge_acceleration
    11:16:06.360 : Unknown option ooze_prevention
    11:16:06.360 : Unknown option avoid_crossing_perimeters
    11:16:06.360 : Unknown option external_fill_pattern
    11:16:06.360 : Unknown option max_print_speed
    11:16:06.361 : Unknown option dont_support_bridges
    11:16:06.361 : Unknown option support_material_interface_layers
    11:16:06.361 : Unknown option interface_shells
    11:16:06.361 : Unknown option thin_walls
    11:16:06.361 : Unknown option spiral_vase
    11:16:06.361 : Unknown option support_material_interface_speed
    11:16:06.361 : Unknown option first_layer_acceleration
    11:16:06.361 : Unknown option resolution
    11:16:06.361 : Unknown option overhangs
    11:16:06.361 : Unknown option seam_position
    11:16:06.361 : Unknown option xy_size_compensation
    11:16:06.361 : Unknown option infill_overlap
    11:16:06.361 : Unknown option raft_layers
    11:16:06.361 : Unknown option external_perimeter_extrusion_width
    11:16:06.361 : Unknown option support_material_contact_distance
    11:16:06.459 : unable to resolve overloaded method for Wx::ComboBox::SetSelection at C:/PROGRA~1/Repetier-Host/Slic3r/lib/std/Slic3r/GUI/Tab.pm line 824
but the manual said that it will come up another small slic3r window. what can i do? what step should i follow? where should i extract the K8200 PLA standard download of zipped file? what is the solution?
Thanks in advance.
hi nice to meet you
Gclub
Download this version from the link below.
http://www.k8200.eu/downloads/files/downloads/setup_repetierhost_k8200_0_95f.zip
This already has the ini files and the drivers.
