When i load some models which consist of several objects (for example the Gyro Cube: http://www.thingiverse.com/thing:40760) there are some parts rendered in green (normally all is rendered in magenta) and after running Slic3r the green parts are missing in the rendered Slic3r output, and of course they are also not printed. In case of the Gyro cube, the smallest sphere is missing.
I’m using Repetier V0.90C, and the Slic3r version which comes originally with this package (Slic3r 0.9.9-dev).
I found nothing in the config settings where i could change this…
Is this a bug, or is there a special trick for handling such models ?
