I have a difficult problem, maybe someone can help me:
Normally the stl file is loaded in Repetier and sliced with Cura or Slic3r. The object is nicely placed in the middle of the printarea.
But now I am trying to work with modifiers* in Slic3r and so generating a gcode directly out of Slic3r to import it in Repetier. Unfortunately the object in preview is then positioned besides the printarea so I can’t print it.
Someone a solution? Thanks in advance.
- To use modifiers you have to use the Plater tab in Slic3r and this is only workable by opening Slic3r independant from Repetier.
