Hey
is it possible to use multiple cards as a slave?
I would need 12 channels, so three cards.
Should I book three separate IP addresses or can I use it through the UART/SPI port slaves and one IP address?
Thanks.
Pieter
Hey
Thanks.
Pieter
You would simply reserve a fixed local IP address for each card through DHCP
is it possible to use them as a master / slave so that I see 12 outputs below eachother without being forced to change of ip
Hi this is currently not possible.
you’ll have to use 3 IP’s.
If you’re a programmer/developer you could write a webpage or piece of software which shows everything on one page.
