Hello
I have updated (2x) the Firmware from V1 to V2. In Arduino show all correct after the update without errors. The Prog Jumper was closed and I had resetted at end.
But in Repetier it shows the same…
11:48:20.021 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:http://www.k8200.com/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:K8200 EXTRUDER_COUNT:1
It so or have I an error?
Thanks for reading and regards
[quote=“Picaflor”]Hello
Thanks for reading and regards[/quote]
That’s normal.
The Firmware name is hardcoded in several places for every language, so they simply left it unchanged.
Thanks for your reply. I had think it is so but not found the correctly positon(s) in the firmware files for a change to try to see the correct version.
No I am relived.
[quote=“Picaflor”]Thanks for your reply. I had think it is so but not found the correctly positon(s) in the firmware files for a change to try to see the correct version.
No I am relived.[/quote]
It is placed in the language.h file.
All languages have the same string, so you could simply do a search and replace to fix it.
That way you will be sure.
cheers,
Christian
[quote]It is placed in the language.h file.
cheers,
Christian
[/quote]
Many thanks Christian, now i can see the correct version in Repetier.
Have a nice day.
Roger
