Shell & Top/bottom thickness in Cura
in Cura>Configuration>Print>Structures>Infill
I have changed the value of shell, top/bottom thickness up to 3mm without noticing change on the pieces, any other part in the interface to check for result?
Also if you are processing a non orthogonal piece it seems to have problems to interpret top & bottom…
Any clues anyone?
