now, after a quite bumpy assembly with some strange problems I finally get my printer working. Yeah!
But after several test prints I´m very disappointed about the really poor quality of my prints. There are several problems, some which I could get managed in some way, others where I have no idea, what may cause these. I´m using a stock K8200 with the z-axis-improvement offert by velleman. I´m very new to 3d printing and there I need some help to get my baby running… there are my issues, please help me solving them.
Prints did not stuck to the plattform. I solved this so far by using an 2.3 mm glass panel I found in my workshop, and added the blue painter tape mentioned in some threads here. After adding the panel, heating up the printbed needs up to about 23-25 minutes to get 50 degree, very long time I think. Do I need a better psu?
In some prints the layers did not stuck to the lower layers and the object was very brittle. I have releveled the heatbed, the lower layers are quite good now, but with more building height, the problem increases, so about 3 or 4 cm, the layers are brittle again. No Idea what to do here.
The precision of the test prints was very poor. Object created in CAD with a messure of 61.5 mm i x dimension get printed between 60.8 and 62.3 mm. y axis has also deviantions about 0.1 to 0.3 mm. Investigating this issue, I found that the pulleys may cause this, the holes for the motor axis are not centered correct, so the pulleys wobble. This may also cause another issue I got, slipping of the ribbons when printing larger objects, ruining the job completely.
By the extreme mass of the printbed, the T5 ribbons are not that good choice I think, maybe better change them to GT2 to get more traction? I this step I could change the pulleys too, which should result in better quality, or not?
- Filament feeding… in 2 of 5 prints filament breaks while printing, I have always to be in sight of the printer, in order to reload the filement to the extruder when it was broken to keep the job running. Sometimes the filement breaks directly from the spool when I try to reload it. I´ve added a small alu pipe to the spool holder to get it easier to rotate, but this seems not to be the cause, nothing has changed since I added it. I using black PLA from velleman for my prints.
Ok, the K8200 is a nice simple and cheap 3d printer, and I know that I could not expect results like from a mendel90 or so. But when I see, what others have printed with the K8200 so far, I really disappointed that my one seems to have some really strange problems. Maybe I´ve done something wrong, but after checking the assembly guide again, I would say, I´ve done it right so far.
So, please give me some advise what I can do to get these nice prints I can see in the “compare your prints” gallery. Thank you very much!
