Would someone using Cura and two printer heads be willing to share their settings? (As long as you are pleased with them of course…)
I would like to try Cura, why stay with Repetier now that I got it to work quite well
But what’s the fun if you can’t have new challenges… So I thought I’d try a shortcut to a fast start.
I’m on a Windows machine if it makes any difference. I’m especially curious about the settings regarding the heat and bed-size, but the more data the happier I would be.
Any other suggestions/help that you can think of is appreciated.
/Mike
*edit
I maybe should make it clear that I’m interested in the actual program Cura https://ultimaker.com/en/products/software, not the settings in Repetier that uses Curas engine to make the code…
