using uno arduino
it doesn’t make a beep
and the left front leg go’s up
and the right front leg go’s 2 the back and it doesn’t stop
any idee
code is
/[color=#FF0000]*VR408
- Copyright © 2014 Velleman nv
- This software may be modified and distributed under the terms
- of the MIT license. See the LICENSE file for details.
#include <Servo.h> // The ALLBOT library needs the servo.h library
#include <ALLBOT.h> // Do not forget to include the ALLBOT library, download it from the manuals.velleman.eu website
ALLBOT BOT(8); // Number of motors
enum MotorName {
hipFrontLeft,
hipFrontRight,
hipRearLeft,
hipRearRight,
kneeFrontLeft,
kneeFrontRight,
kneeRearLeft,
kneeRearRight
long randNumber0; // This variable is used for random function
long randNumber1; // This variable is used for random function
int sounderPin = 13; // Declaring what pin the sounder on the VRSSM is connected to
String rawcommand; // Global variable that stores the raw received IR command
String command; // Global variable that stores part of the decoded IR command
int times; // Global variable that stores part the received IR command
int speedms; // Global variable that stores part the received IR command
boolean IRreceive = true; // Set this to true if you want to use the IR remote
boolean receivelog = false; // Set this to true if you want to see the serial messages for debugging the IR commands
void setup()
// NAME.attach(motorname, pin, init-angle, flipped, offset-angle);
BOT.attach(hipFrontLeft, A1, 45, 0, 0);
BOT.attach(hipFrontRight, A0, 45, 1, 0);
BOT.attach(hipRearLeft, 9, 45, 1, 0);
BOT.attach(hipRearRight, 4, 45, 0, 0);
BOT.attach(kneeFrontLeft, 11, 45, 1, 0);
BOT.attach(kneeFrontRight, 2, 45, 0, 0);
BOT.attach(kneeRearLeft, 10, 45, 1, 0);
BOT.attach(kneeRearRight, 3, 45, 0, 0);
// INIT sounder
pinMode(sounderPin, OUTPUT);
// Wait for joints to be initialized
delay(500);
// Starting the hardware UART, necessary for receiving IR
if (IRreceive == true) // Check if required (when Serial is started servo1 connector will not work!)
Serial.begin(2400);
Serial.setTimeout(100);
Serial.println(“serial communication started”);
// INIT the random seed, this is used to create random actions
randomSeed(analogRead(5));
// Chirp for ready
chirp(1, 50);
chirp(1, 255);
chirp(3, 0);
void loop() // Main program loop
if (IRreceive == true) // Choose between IR commands or random action
getcommand(); // Listen for IR command
executecommand(); // Execute any receveid commands
else
randNumber0 = random(0, 18);
randNumber1 = random(0, 20);
delay(randNumber1*100);
switch (randNumber0) { // This is the random action case
case 0:
randNumber0 = random(10, 255);
leanforward(randNumber0);
break;
case 1:
leanbackward(randNumber0);
break;
case 2:
leanleft(randNumber0);
break;
case 3:
leanright(randNumber0);
break;
case 4:
lookleft(randNumber0);
break;
case 5:
lookright(randNumber0);
break;
case 6:
randNumber1 = random(1, 5);
turnleft(randNumber1, randNumber0);
break;
case 7:
turnright(randNumber1, randNumber0);
break;
case 8:
randNumber0 = random(10, 150);
randNumber1 = random(2, 10);
walkforward(randNumber1, randNumber0);
break;
case 9:
walkbackward(randNumber1, randNumber0);
break;
case 10:
walkleft(randNumber1, randNumber0);
break;
case 11:
walkright(randNumber1, randNumber0);
break;
case 12:
randNumber0 = random(5, 30);
scared(randNumber1, randNumber0);
break;
case 13:
randNumber0 = random(0, 255);
randNumber1 = random(1, 30);
chirp(randNumber1, randNumber0);
break;
case 14:
randNumber0 = random(25, 100);
wavefrontright(randNumber1, randNumber0);
break;
case 15:
wavefrontleft(randNumber1, randNumber0);
break;
case 16:
waverearright(randNumber1, randNumber0);
break;
case 17:
waverearleft(randNumber1, randNumber0);
break;
void getcommand (void) // This is the routine that listens and decodes any IR commands. Decodes commands end up in the global vars.
int space1 = 0;
int space2 = 0;
if (Serial.available()) {
rawcommand = Serial.readString();
if (receivelog){
Serial.println(“START " + rawcommand + " END” + “\r\n” + "Received string length = " + rawcommand.length() + “\r\n” + "End character > at index = " + rawcommand.indexOf(’>’));
//checking and deleting rubbish data at start of received command
if ((rawcommand.indexOf('<') != 0) && (rawcommand.indexOf('<') != -1))
rawcommand.remove(0, rawcommand.indexOf('<'));
//check if received command is correct
if ((rawcommand.charAt(0) == '<') && (rawcommand.indexOf('>') <= 12) && (rawcommand.indexOf('>') != -1) && (rawcommand.length() > 7))
if (receivelog){
Serial.println("Command is VALID");
//breakdown into chunks
//command
command = rawcommand.substring(1, 3);
//finding the spaces to find the times and speedms
for (int i=0; i <= rawcommand.length(); i ++)
if ((rawcommand.charAt(i) == ' ') && (space1 == 0))
space1 = i;
else if ((rawcommand.charAt(i) == ' ') && (space2 == 0))
space2 = i;
//Setting the command variables and checking if they are indeed a number (toInt()).
//times
times = rawcommand.substring(space1+1, space2).toInt();
//speedms
speedms = rawcommand.substring(space2+1, rawcommand.indexOf('>')).toInt();
if (receivelog){
Serial.println("decoded commands are:");
Serial.flush();
Serial.println("command = " + command);
Serial.flush();
Serial.println("times = " + times);
Serial.flush();
Serial.println("speedms = " + speedms);
else
if (receivelog){
Serial.println("Command is NOT valid");
resetserial();
void resetserial (void) // This clears any received IR commands that where received in the serial buffer while the robot was execution a command.
//resetting all variables
rawcommand = “”;
command = “”;
times = 0;
speedms = 0;
//flushing the serial buffer (64 byte) so there are no stored movements that need to be handled (annoying)…
while (Serial.available()) {
Serial.read();
void executecommand (void) // Execute the commands that are stored in the global vars.
if (command == “WF”)
walkforward(times, (speedms5));
resetserial();
else if (command == “WB”)
walkbackward(times, (speedms5));
resetserial();
else if (command == “WL”)
walkleft(times, (speedms5));
resetserial();
else if (command == “WR”)
walkright(times, (speedms5));
resetserial();
else if (command == “TR”)
turnright(times, (speedms5));
resetserial();
else if (command == “TL”)
turnleft(times, (speedms5));
resetserial();
else if (command == “LF”)
leanforward(speedms5);
resetserial();
else if (command == “LB”)
leanbackward(speedms5);
resetserial();
else if (command == “LL”)
leanleft(speedms5);
resetserial();
else if (command == “LR”)
leanright(speedms5);
resetserial();
else if (command == “FR”)
wavefrontright(times, speedms5);
resetserial();
else if (command == “FL”)
wavefrontleft(times, speedms5);
resetserial();
else if (command == “RR”)
waverearright(times, speedms5);
resetserial();
else if (command == “RL”)
waverearleft(times, speedms5);
resetserial();
else if (command == “SC”)
scared(times, speedms);
resetserial();
else if (command == “CH”)
chirp(times, speedms);
resetserial();
void chirp(int beeps, int speedms){
for (int i = 0; i < beeps; i++){
for (int i = 0; i < 255; i++){
digitalWrite(sounderPin, HIGH);
delayMicroseconds((355-i)+ (speedms2));
digitalWrite(sounderPin, LOW);
delay(30);
void waverearleft(int waves, int speedms){
BOT.move(kneeRearLeft, 180);
BOT.animate(speedms);
for (int i = 0; i < waves; i++){
BOT.move(hipRearLeft, 0);
BOT.move(hipRearLeft, 65);
BOT.move(hipRearLeft, 45);
BOT.move(kneeRearLeft, 45);
void waverearright(int waves, int speedms){
BOT.move(kneeRearRight, 180);
BOT.move(hipRearRight, 0);
BOT.move(hipRearRight, 65);
BOT.move(hipRearRight, 45);
BOT.move(kneeRearRight, 45);
void wavefrontright(int waves, int speedms){
BOT.move(kneeFrontRight, 180);
BOT.move(hipFrontRight, 0);
BOT.move(hipFrontRight, 65);
BOT.move(hipFrontRight, 45);
BOT.move(kneeFrontRight, 45);
void wavefrontleft(int waves, int speedms){
BOT.move(kneeFrontLeft, 180);
BOT.move(hipFrontLeft, 0);
BOT.move(hipFrontLeft, 65);
BOT.move(hipFrontLeft, 45);
BOT.move(kneeFrontLeft, 45);
void scared(int shakes, int beeps){
BOT.move(kneeFrontRight, 0);
BOT.move(kneeRearRight, 0);
BOT.move(kneeFrontLeft, 0);
BOT.move(kneeRearLeft, 0);
BOT.animate(50);
for (int i = 0; i < shakes; i++){
BOT.move(hipRearRight, 80);
BOT.move(hipRearLeft, 10);
BOT.move(hipFrontRight, 10);
BOT.move(hipFrontLeft, 80);
BOT.animate(100);
BOT.move(hipRearLeft, 80);
BOT.move(hipRearRight, 10);
BOT.move(hipFrontLeft, 10);
BOT.move(hipFrontRight, 80);
BOT.animate(50);
BOT.animate(200);
chirp(beeps, 0);
BOT.animate(75);
void leanright(int speedms){
BOT.move(kneeFrontRight, 90);
BOT.move(kneeRearRight, 90);
delay(speedms/2);
void leanleft(int speedms){
BOT.move(kneeFrontLeft, 90);
BOT.move(kneeRearLeft, 90);
delay(speedms/2);
void leanforward(int speedms){
delay(speedms/2);
void leanbackward(int speedms){
delay(speedms/2);
void lookleft(int speedms){
delay(speedms/2);
void lookright(int speedms){
delay(speedms/2);
void walkforward(int steps, int speedms){
for (int i = 0; i < steps; i++){
BOT.move(kneeRearRight, 80);
BOT.move(kneeFrontLeft, 80);
BOT.move(hipFrontLeft, 20);
BOT.move(kneeRearRight, 30);
BOT.move(kneeFrontLeft, 30);
BOT.move(kneeRearLeft, 80);
BOT.move(kneeFrontRight, 80);
BOT.move(hipFrontRight, 20);
BOT.move(kneeRearLeft, 30);
BOT.move(kneeFrontRight, 30);
void walkbackward(int steps, int speedms){
BOT.move(hipRearRight, 20);
BOT.move(hipRearLeft, 20);
void walkleft(int steps, int speedms){
BOT.move(hipFrontLeft, 90);
BOT.move(hipRearLeft, 90);
void walkright(int steps, int speedms){
BOT.move(hipFrontRight, 90);
BOT.move(hipRearRight, 90);
void turnleft(int steps, int speedms){
void turnright(int steps, int speedms){
//--------------------------------------------------------------[/color]
