Hi! I bought the VMA01 “no soldering required” version.
How do I select 6A external power supply? My board came preassembled and the 2A jumper pin is soldered (!) to power. Also the 6A hole is soldered shut to prevent any solderless connections.
How do I connect 6A external power supply without soldering?
I think this is not possible and that you have to solder the jumper pins in the correct configuration.
Is here any official response to this topic?
On the package a big icon “no soldering required” is printed. And now I have to solder the jumper pins?! Why is there no usual jumper?
6 amps is a lot of current.
Jumper pins may not be able to handle that much.
