Second feeder
Hello , i bought a second nozle / feeder and instald it updated the firmware but it doesn’t work . Can’t load the fillament motor doens’t move …
Sounds like you are taking about the K8400.
You should really post this in that section.
You know the driver card mounts 180 degrees from the rest of them, correct?
If you reloaded the firmware you need to use Arduino software 1.0.6 or lower.
The higher versions do not get along with the Velleman printers.
[quote=“Wrong Way”]Sounds like you are taking about the K8400.
The higher versions do not get along with the Velleman printers.[/quote]
No i did not … thank you verry much ! I’m running 1.6.7 an it works fine .
So it’s working now?
Yes thank you !
Glad to hear that.
Enjoy!
