Hallo,
my 2. extruder don’t work.
I can load filament, but it don’t work while printing.
the stepper driver is checked an is (above) in the tolerance.
and before someone say “check your firmware!”
It’s the latest one for two heads…
You don’t say what you were trying to do : print with the two heads at the same time or print with head 2 alone?
I’ll assume the latest : when placing your object, select head 2 (EXTR2). In the Slicer tab select “Vertex Single head” in Print configuration.
Thanx Raby. Now it works.
I thought I have to use always the “dual extruder”. And maybe change only “T0” to “T1”.
But it’s a bit more…
You’re welcome. It’s not really intuitive and I’ve had the same issue the first time I tried to use the second extruder.
