Hy!
I dowloaded the marlin v2 firmvare from k8200.eu. Then I updated the k8200 software. The LCD, buttons and rotary encoder work good, but in menu I see: ‘No card’. I tryed the “init sd card” but its not work. What is the problem? Another firmvare from internet its work all but the printing speed is dont adjustable.
Can everybody help me?
Thanks and best regards!
Benji
Which arduino version did you use to compile it?
Only 1.0.6 works. Later versions, including 1.6.0 don’t compile marlin correctly.
Hallo Bennji1992,
ich hatte auch das Problem mit dieser Fehlermeldung “init sd cd card …”,
ich denk das hat was damit zu tuen das die Hardware & Software keine SD-HC Card unterstützt, mit reinen SD-Card (bis 4GB, die gibt es NOCH für ältere Digital-Foto-Kammera)
funktioniert das ohne Probleme. Schade das Velleman hier etwas mit dem aktuellen Stand der Technik etwas hinterherhinkt.
EN
Hello Bennji1992,
I also had the problem with this error message “init cd sd card …”
I think it has something to do with the hardware & software not the SD-HC card support, with pure SD Card (up to 4GB, it is STILL for older digital photo camera)
it works without problems. Too bad the Velleman something a bit lagging behind at the cutting edge of technology.
