Could I use the HPS140 to set gain on home audio amplifiers and home theatre receivers? Maximum voltage output is 40 volts(AC I guess). Also, could I use the HPG1 generator to act as an audio source when setting gain using the HPS140.
Thanks in advance,
Shane
Yes, this is perfectly possible.
Thank you
