I finished bouilding my 3D printer last week and I noticed that I have some scale problems on the objects I print.
For example, I tried to print this part which is supposed to be 50mm * 50 mm (thingiverse.com/thing:53668/#instructions).
I measured it and I got: On x axis :50.9mm and on y axis it’s even worse with 53.9 mm.
Do NOT mess with the stepper settings to correct part sizes!
50.9mm is pretty close taking into account variations in extrusion widths, 53.9 is out quite a bit and sounds like you may have an out of spec toothed pulley.
Send M503 to get all the configuration settings, like steps per mm.
Check that the axes are actually moving by the requested amount.
Send ‘G1 X100’ (move X axis 100mm) and measure the actual distance moved.
Repeat for the Y axis.
There are various online ‘reprap’ calculators that will give you the steps per mm for your belt pitch, pulley tooth count and stepper setup.
Thanks for your advices. I ordered new pulleys and I will try them. For the moment I cheated and modified the firmware to get something quite correct (0.5 mm on a 50mm piece).
I will keep you informed when I have my new pulleys;
