RS 232 comm with K8056
hi
Today I assembled my K8056 board (I am a beginner on this).
It looks OK, but I am not sure.
When I connect the power, I see all leds burning and all swiches make a single click (is this on?).
Is this normal?
I am suprised to see the data led burning because there is no communiction yet.
When I link the computer and start the demo appl (and try different options)
I don’t see anything happening (not even a blink from the data led).
Did I do something wrong?
Also the button on the board does not do anything.
Hans
Leiderdorp, NL
Once again just a guess.
Is IC 1 mounted correctly?
Hi
Thanks for the suggestion, but I think the IC is correctly mounted.
Hans
Check if PIC receives +5V.
If this is the case and the button on the board does not work, then we suspect a defective or empty PIC.
You can return it to:
Velleman Projects
Legen Heirweg 33
9890 Gavere
Belgium
