Is it necessary to remove the Ni-MH batteries?
for long life of the batteries, while using the adapter 9Vdc. There is risk of damage HPS140i not operate without batteries using 9Vdc adapter?
for long life Ni-MH battery:
a)must be used to completely discharge HPS140i, then load X7 hours with USB adapter?
b)you can charge the battery from adapter 9VDC HPS140i off? or only possible with USB adapter?
risk of damage to the battery or HPS140i by these methods?
It is not necessary to remove the batteries when using the USB or 9VDC adaptor.
The battery charges from either the USB or a 9VDC adaptor.
It is not necessary to completely drain the batteries, NiMH suffer less from memory effect than NiCd batteries.
