If you’re like me, often rebuilt the printer, you need a lot of cable ties to fix all cable.I designed a wider clip which holds the ribbon cable straight on the frame and a second clip for thicker cable (3-4mm diameter). See at thingiverse
This is very nice, thank you very much!
~ Tectu
