Hello, on the pcb of this kit K2573 an IC should be installed in an IC mounting foot. Where is pin #1 on the IC? The IC is a 39ALJ1M TL072CP and I can see a dot that is moulded in the IC’s plastic material. Is the dot near pin #1?
Thank you, Willem Houweling
Yes, the dot is the closest to pin 1.
