Make fine prints with Vertex Repetier but now I have to print an object with infill only. I think this can’t be done in Repetier so I moved to Simplify3d where I can set top, bottom and shells to zero. I am using the optimized settings from Jakemog22 and it does print but I have a regularly retraction in the extruder, even when printing straight lines. Altered some settings but it won’t help. There’s no clogged nozzle or something like that, when I print with Repetier, it’s ok.
Someone an idea?
