Response time K8056
I have a K8056 board.
I noticed that the relais response time after a control instruction is 320 ms.
This is a long time.
I noticed that the relais were activated only after the data led was lit on and off again.
So in the program, the led was lit first, then during 320ms nothing was done and then when the led is switched off again, the relais is activated.
In my opinion it is better to first activate the relais and then activate the led during some time (100ms is good enough).
Does anyone know if this has been improved in the usb version.
Michiel
