Replacement of TRIAC in K8064
Dear Gents
I´ve blown the TRIAC of the K8064 caused by the short cut of a bulb. Now I´ve replaced the old and blown one by a BTA 08 600 B and the dimmer will not work and displays the error code by means of TRIAC defect by three flashes by the green light. What shall I do that this device will work again?
Met vreindlijke groet from Hamburg Germany
Lemmi
–> I assume you did check that both Triacs are compatible: pinning , current (both main and gate) and max voltage.I can not get hold of the datasheet of your replacement triac.
–> Did you also replace fuse F1? It is almost 100% certain also blown together with the triac. :shock:
