Repetier when sliced the model is invisible
Hmm, after Cura slicing the model dissapears from the preview window and I can’t browse layers or anything like that?
Is this a common issue? Running latest version under win7.
At the top of the screen click on Show Filament.
You may not be able to have that on while printing.
This depends on your video card.
I had this once and discovered that I designed my walls thinner than the wall thickness setting in Cura. I think if the Cura settings doesn’t allow something in your design, it does not show up after slicing.
Thanks for the feedback!
8400,
Did anything fix it?
If so could you post the solution?
Yep - “Show Filament” option - WIN!
