Repetier software
When will the repitier software be updated so it runs proprerly With Win 10?
What kind of problem are you having.
I have been running it on Win 10 for over a year with no issues.
Hi my problem with repetier SW is that the PC will not switch off after using Repeiter.
The Repeiter SW is terminated, the USB Connection removed and I select switch off on the PC.
The PC will not switch off! Only way is to pull the power to it or press the start button for 5 sec.
