Hello!
I just want to update my data for all of you who want to use RepetierHost on linux. Just to repeat again: I’m using Debian on kernel 3.18 amd64.
Further details can be found above, in my last post.
Here you find the most interesting files :~/.local/share/RepetierHost/composition0.stl
~/.local/share/RepetierHost/composition.amf
~/.local/share/RepetierHost/composition.gcode
~/.local/share/RepetierHost/cura.ini
~/.local/share/RepetierHost/repetier.log
~/.local/share/RepetierHost/slic3r.ini
Additionaly I created these files by adding my printer so there is a new subfolder containing my modifications:
~/.local/share/RepetierHost/CuraEngine/velleman vertex (k8400)/filament/Default.ini
~/.local/share/RepetierHost/CuraEngine/velleman vertex (k8400)/filament/PLA_grau.ini
~/.local/share/RepetierHost/CuraEngine/velleman vertex (k8400)/filament/PLA_SW.ini
~/.local/share/RepetierHost/CuraEngine/velleman vertex (k8400)/filament/PLA_weiß.ini
~/.local/share/RepetierHost/CuraEngine/velleman vertex (k8400)/print/Default.ini
~/.local/share/RepetierHost/CuraEngine/velleman vertex (k8400)/print/langsam.ini
Now I also found out how to configure the endstop position so movement in the manual control tab is now working correctly.
Here you’ll get my ~/.local/share/RepetierHost/cura.ini[code]layerThickness = 205
initialLayerThickness = 300
filamentDiameter = 1750
filamentFlow = 90
extrusionWidth = 400
layer0extrusionWidth = 400
insetCount = 2
infillOverlap = 15
initialSpeedupLayers = 4
initialLayerSpeed = 15
printSpeed = 17
infillSpeed = 62
inset0Speed = 21
insetXSpeed = 62
moveSpeed = 53
fanSpeedMin = 50
fanSpeedMax = 100
supportAngle = 60
supportEverywhere = 0
supportLineDistance = 2666
supportXYDistance = 700
supportZDistance = 150
supportExtruder = -1
retractionAmount = 4000
retractionSpeed = 40
retractionMinimalDistance = 1500
retractionAmountExtruderSwitch = 16000
retractionZHop = 105
minimalExtrusionBeforeRetraction = 20
enableCombing = 1
multiVolumeOverlap = 0
objectSink = 0
minimalLayerTime = 5
minimalFeedrate = 10
coolHeadLift = 0
extruderOffset[0].X = 0
extruderOffset[0].Y = 0
fixHorrible = 0
fanFullOnLayerNr = 1
supportType = 0
infillPattern = 2
sparseInfillLineDistance = 2000
downSkinCount = 3
upSkinCount = 3
skirtDistance = 0
skirtLineCount = 8
gcodeFlavor = 0
spiralizeMode = 0
enableOozeShield = 0
autoCenter = 0
startCode = “”"
; Default start code
G28 ; Home extruder
G1 Z9 F100
M107 ; Turn off fan
G90 ; Absolute positioning
M82 ; Extruder in absolute mode
; Activate all used extruder
M104 T0 S190
G92 E0 ; Reset extruder position
; Wait for all used extruders to reach temperature
M109 T0 S190
endCode = “”"
; Default end code
;G1 X0 Y0 Z130 ; Get extruder out of way. Uncomment to use!
M107 ; Turn off fan
; Disable all extruder
G91 ; Relative positioning
T0
G1 E-1 ; Reduce filament pressure
M104 T0 S0
M140 S0 ; Disable heated bed
M84 ; Turn steppers off
preSwitchExtruderCode = “”"
postSwitchExtruderCode = “”"
[/code]
This is my ~/.local/share/RepetierHost/CuraEngine/velleman vertex (k8400)/print/langsam.ini
[print]
name = langsam
defaultQuality = Put_your_GUID_here
travelSpeedMin = 50
travelSpeedMax = 90
firstLayerSpeedMin = 15
firstLayerSpeedMax = 20
infillSpeedMin = 60
infillSpeedMax = 90
infillType = 2
innerPerimeterMin = 30
innerPerimeterMax = 50
outerPerimeterMin = 20
outerPerimeterMax = 40
printSpeedMin = 15
printSpeedMax = 40
nozzleDiameter = 0
gcodeFlavour = 0
retractionCombing = True
cutOffObjectBottom = 0
shellThickness = 0.8
infillTopBottomThickness = 0.6
infillDensityPercent = 20
supportType = 0
platformAdhesion = 0
dualExtrusion = 0
wipeAndPrimeTower = False
oozeShield = False
enableRetraction = True
retractionDistance = 4
multiExtruderSwitchAmount = 16
startGCode = """
G28 ; Home extruder
G1 Z9 F{Z_TRAVEL_SPEED}
M107 ; Turn off fan
{IF_BED}M190 S{BED}
{IF_EXT0}M104 T0 S{TEMP0}
{IF_EXT0}M109 T0 S{TEMP0}
endGCode = """
; Default end code
M107 ; Turn off fan
{IF_EXT0}T0
{IF_EXT0}G1 E-1 ; Reduce filament pressure
M104 T0 S0
wipeAndPrimeTowerVolume = 15
retractionMinimumTravel = 1.5
minimumExtrusionBeforeRetract = 0.02
zhop = 0.105
skirtLineCount = 1
skirtDistance = 3
skirtMinimumLength = 150
solidInfillTop = True
solidInfillBottom = True
infillOverlapPercent = 15
supportStructureType = 0
supportOverhang = 60
supportFillPercent = 15
supportDistanceXY = 0.7
supportDistanceZ = 0.15
spiralizeOuterContour = False
brimWidth = 3
raftExtraMargin = 4
raftLineSpacing = 1
raftBaseThickness = 0.3
raftBaseWidth = 0.7
raftInterfaceThickness = 0.2
raftInterfaceLineWidth = 0.2
raftAirGap = 0
raftAirGapLayer0 = 0
raftSurfaceLayer = 1
fixCombineEverythingA = False
fixCombineEverythingB = False
fixKeepOpenFaces = False
fixExtensiveStitching = False
fanFullAtHeight = 0.5
minimumSpeed = 10
coolHeadLift = False
numQuality = 1
[quality_0]
name = 0.2 mm
signature = Put_your_GUID_here
layerHeight = 0.205
layer0widthPercent = 100
firstLayerHeight = 0.3
And here are my filamentfiles for PLA in grey, black and white.
[filament]
name = PLA_grau
diameter = 1.75
multiplierPercent = 90
printingTemperature = 190
enableCooling = True
bedTemperature = 0
fanSpeedMin = 50
fanSpeedMax = 100
[filament]
name = PLA_SW
diameter = 1.75
multiplierPercent = 85
printingTemperature = 200
bedTemperature = 0
fanSpeedMin = 50
fanSpeedMax = 100
~/.local/share/RepetierHost/CuraEngine/velleman vertex (k8400)/filament/PLA_weiss.ini
[filament]
name = PLA_weiss
diameter = 1.75
multiplierPercent = 95
printingTemperature = 192
bedTemperature = 0
fanSpeedMin = 50
fanSpeedMax = 100
Again, I would be very glad if some of you would share their experiences and modificatons to these ini-files.
Thx
